Metro quits when using notation eraser
Postby fastlanephil » Wed Feb 22, 2012 10:04 pm
With Metro 6.5.0.2 using the notation eraser causes Metro to quit. OSX 10.7.3
Phil
Re: Metro quits when using notation eraser
Postby Jerm » Thu Feb 23, 2012 4:38 am
Thanks for the report.
Under OS 10.5.8 it works fine on my iMac.
Does it repeat? If you start with a fresh document add a note and delete it does it do it then?
Postby fastlanephil » Fri Feb 24, 2012 12:51 am
I started with a new project and added a note in the Notation Editor. I erased it with no problem. I then added two notes and when I erased the second note Metro quit.
Phil
Postby Jerm » Fri Feb 24, 2012 2:51 am
Well I tried it on 10.6.8 and it worked fine.
When it quits is it a crash? Do you see anything in the console program when it quits?
Postby fastlanephil » Fri Feb 24, 2012 1:12 pm
This is the box that comes up after Metro quits.
Here is the first part of the Details. The Details are several pages long and too wide to fit in here.
Phil
Postby Jerm » Fri Feb 24, 2012 2:48 pm
That is helpful. Thanks phil. I will contact you directly to try to get this resolved ASAP.
Postby Jerm » Sat Feb 25, 2012 1:26 am
This has been fixed.
