Problems playing back audio in Metro 5
Postby J.B. » Sat Oct 18, 2003 2:29 pm
I have an iBook with a USB Quattro Audio Card. I want to record more than one audio track and Metro doesn't allow me. When I record my audio tracks it does not play them back. I can open them and play them back with a demo version I got of Metro 6 but why won't it play on Metro 5?
J.B.
Postby Jerm » Sat Oct 18, 2003 4:29 pm
J.B.
Perhaps you do not have your audio device or your instruments configured properly.
Postby Scoot » Sat Oct 18, 2003 9:55 pm
If you can see levels in the tracks window on playback, then it's a matter of modifying the instruments and busses from the special menu to allocate tracks to the audio out device to hear what's being played.
Problems playing audio in Metro 5
Postby J.B. » Mon Oct 27, 2003 6:15 pm
Thanks for your help Jerm and Scoot for your help I did what you advised me and it worked. :D
J.B.
Postby Scoot » Mon Oct 27, 2003 6:53 pm
I think the port configuring between 5 and 6 is a little different.
Under 6 you find some things automatically set themselves when you make adjustments.
Under 5 it waits for you to make some changes manually........the older version is a little harder to configure and setup.
It's good you got there in the end.
Return to Older Products QA
