GSpro wrote:In the Arpeggiator Pattern Window, along with the Trans-Vel-Dur, would it be possible to add Up Strum & Down Strum. I think it would give the user better and more programmabilty options.
The settings would have to deal with how the strings are strummed, e.g. gost notes, Down strum lets say 5-6 strings, Up strum maybe 3-4 and vice versa.
GSpro wrote:How about a free form strum feature. This can be useful in live situations, improvisation, or to get a quick idea down.
Jerm wrote:GSpro wrote:In the Arpeggiator Pattern Window, along with the Trans-Vel-Dur, would it be possible to add Up Strum & Down Strum. I think it would give the user better and more programmabilty options.
This is a good idea. I am still evaluating this so please be patient.
Yes Sir.GSpro wrote:How about a free form strum feature. This can be useful in live situations, improvisation, or to get a quick idea down.
This is basically already implemented. What you need to do for this functionality is to simply apply two (or more) remote control note commands so that when a key is pressed the arp method is changed from up to down. I have created such a preset that can be downloaded here. Control click on the above link and select save linked file as then place it into your presets folder within the Metro folder.
Another way to do it with even more control would be to have two patterns, one with up strumming and one with down strumming and then use remote control to switch between the two patterns. This way the spread or the patterns could be slightly different.
Jerm wrote:This is basically already implemented. What you need to do for this functionality is to simply apply two (or more) remote control note commands so that when a key is pressed the arp method is changed from up to down. I have created such a preset that can be downloaded here. Control click on the above link and select save linked file as then place it into your presets folder within the Metro folder.
Jerm wrote:Another way to do it with even more control would be to have two patterns, one with up strumming and one with down strumming and then use remote control to switch between the two patterns. This way the spread or the patterns could be slightly different.
Jerm wrote:• Open the remote control window
• From the insert menu select 'note on'
• Change the device, channel and pitch if necessary
• Change the command to 'arp method' or 'arp pattern' depending on what you want
• In the parameters section the default is to 0-127 0-127. You want to change this so that the arp method (or arp pattern) will change regardless of the note velocity.
Jerm wrote:So double click on the 0-127's and a dialog will come up.
Jerm wrote:Select the 'map to output range of' checkbox. Change the output range for the command. Arp Methods currently are:
0 = updown
1 = updownedges
2= up
3 = down
4 = chords
5 = diatonic chords
GSpro wrote:Hello Sir,
I think I'm missing something somewhere and I need your help.Jerm wrote:• Open the remote control window
To get to the parameters section I have to double click in the highlighted area of the remote control window. Correct?
GSpro wrote:Jerm wrote:So double click on the 0-127's and a dialog will come up.
Double clicking on the 0-127, no dialog comes up.
GSpro wrote:Where do I enter this information? In the StrumControl file that I've downloaded?
Jerm wrote:Yes that is my fault. Sorry for the trouble.
Users browsing this forum: No registered users and 31 guests
