URE: "Extended Jam"
URE: "Extended Jam"
Postby Lytz1 » Fri Nov 02, 2018 5:15 pm
So. Another idea that I thought about quite often actually
but I always forgot to mention it.
Wouldn't it be cool if the "Jam" Function could be extended so that the
URE jumps to another random pattern every bar?
That truly would be jamming, right?
(This also would allow the "jam" function to work with songs that have
chord/scale changes. Right now you have to play through the whole chord/scale changes until the next pattern
gets triggered.)
Re: URE: "Extended Jam"
Postby Jerm » Fri Nov 02, 2018 7:22 pm
I don't understand. The patterns are random so what is the difference?
Postby Lytz1 » Fri Nov 02, 2018 8:25 pm
Jam mode right now:
Generated Pattern must play through completely to switch to the next pattern.
(1 to 2, then to 3 and so on.)
My thoughts:
Jam mode jumps to another random pattern on a per bar-basis, thus before it is completed.
Might be more useful for the normal Arps, maybe not that much for the LG.
Might be redundant though, because of the split-to-layer feature. Not sure.
